Old 04-18-2013, 12:30 AM
69VN's Avatar
69VN 69VN is offline
Default 1967-68 Camaro L48 Harmonic Balancer GM
This is a used original GM 8" harmonic balancer which is correct for 1967-68 Camaro SS350 L48 engine. Has the numbers 6966 & HI 69 stamped on the backside. The front side has 7704H 38 stamped near the seal. The overall condition is nice. All threads on mounting holes are good, the rubber seal is intact and the keyway is in great condition. *Asking $65 plus shipping to lower 48 states. PM me with any questions. Thanks.
I currently own a 1969 Camaro SS350. Although the original drivetrain is long gone, this 4/speed car has a March '69 HC coded block with #041 heads. The transmission is an M20 Muncie #660 case and the rearend is a BS coded 12 bolt posi. Built in Van Nuys.
