Old 04-18-2013, 11:36 AM
69VN's Avatar
69VN 69VN is offline
Default 1967-69 Camaro Shock Mounting Brackets Original GM
This is a pair of used original shock absorber mounting brackets with original bolts that were removed from my '69 Camaro. Not in bad shape but need to be cleaned up. Bolts and threads are good. Was told these can be used on 1967-69 Firebirds and 1968 & up Novas. *Asking $30 with shipping included to lower 48 states. PM me with any questions. Thanks.
I currently own a 1969 Camaro SS350. Although the original drivetrain is long gone, this 4/speed car has a March '69 HC coded block with #041 heads. The transmission is an M20 Muncie #660 case and the rearend is a BS coded 12 bolt posi. Built in Van Nuys.
