Old 04-21-2013, 05:23 PM
Donnie's Avatar
Donnie Donnie is offline
Default Heater Box
What are you guys using to seal the heater box to the cowl?
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 04-21-2013, 06:37 PM
x77-69z28's Avatar
Default Re: Heater Box
Dum-dum. 3M strip caulk part number is 8578. How is the car coming?
Old 04-21-2013, 08:06 PM
SS427's Avatar
SS427 SS427 is offline
x2
Rick Nelson
Old 04-21-2013, 10:47 PM
Donnie's Avatar
slowly but its getting there.
working on under the dash stuff right now.
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 04-21-2013, 11:49 PM
Don`t forget to use a lot of Dielectric Grease [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 04-22-2013, 01:48 AM
Donnie's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Postsedan</div><div class="ubbcode-body">Don`t forget to use a lot of Dielectric Grease [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Dan </div></div>
will do.
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 04-22-2013, 01:49 AM
Donnie's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: x77-69z28</div><div class="ubbcode-body">Dum-dum. 3M strip caulk part number is 8578. How is the car coming? </div></div>
is it safe to assume that this is also used to seal the kick panels?
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 04-22-2013, 02:40 AM
Correct. Question, did you not do all of this when you restored your '70.....as its the same procedure.
Old 04-22-2013, 06:14 AM
Donnie's Avatar
didnt take the A/C box off the 70 all it needed was cleaned up.
think I used some stuff called mortite on the kick panels.
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 04-22-2013, 02:03 PM
SS427's Avatar
For kick panels use a product called Duct Seal made by Ideal Industries and available at most large box hardware stores. There are other manufacturers such GB who make it as well. It is used by electricians and plumbers to seal pipes or electrical where the enter or exit a dwelling. Looks and works just like the original seal applied to kick panels.
http://www.idealindustries.com/prodD...l1=accessories
It comes in a brick and you just use a razor blade to cut it to size, roll it into a rope between your hands and apply it to the kick panel.
Rick Nelson
