Old 05-16-2013, 04:18 AM
cwc's Avatar
cwc cwc is offline
Default rebuilding my l36 427,need piston advice
well im going thru my 427 in my 67 impala,the original owner rebuilt in the late 80's using l2268 pistons and the original heads,just a tad bit too much compression! im lookin at the l2300f with .140 dome.im thinking this will get me back close to my original 10.25 to 1. will these work with my original closed chamber heads? ive thought of using keith blacks,as i just finished building a 66 396/325 and had issues with the speedpro repalcements hittin my heads
1967 SS427 4 speed triple black survivor-sold to a good home
1969 nova SS396 L78 4 speed triple black survivor
1970 camaro SS350 citrus green,Dad bought it new!
1968 chevelle ss396 L34 M21 KK rear all born with
1972 formula 400 M22
Old 05-16-2013, 02:41 PM
earntaz earntaz is offline
Default Re: rebuilding my l36 427,need piston advice
I am about to do the same -- let's see what the panel says. I have looked at hyper and forged pistons and both have their advantages. If the RPM is kept below 6500 I think hypers will do the job with less piston slap due to tighter tolerances -- also better oil control. Many new HP engines use the hyper pistons. Forged work well also -- best at higher RPM ranges.
I will be using a set of 063s (right at 100cc) with a lot of porting work.
So I'll stand by for the experts ...
The TAZ
Old 05-16-2013, 02:42 PM
The TAZ
Geezzee -- sorry for the double post ...!@#$
Old 05-16-2013, 03:20 PM
Jerry MacNeish had the same problem with a 1965 396 that he just built for his Impala. The stock OEM pistons hit the heads.
Old 05-16-2013, 04:03 PM
VintageMusclecar's Avatar
Assuming the following:
4.280 bore
3.76 stroke
98.4 c.c chamber (702 or 390 head castings)
16.8 c.c. dome (spec for L2300)
Piston .020 down in the hole (un-decked block)
.040" head gasket
Approx. 10.27-1 compression
Change the chamber volume to 101 c.c. (802 head castings)
Approx. 10.0-1 compression.
For a <span style="font-weight: bold"><span style="text-decoration: underline">stock or very mild performance rebuild</span></span>, cast or hypereutectics are fine. For anything you're going to lean on, I would recommend forgings.
If you would like any help or advice on selecting a piston, I'll be happy to help.
Old 05-16-2013, 04:56 PM
Have you any recommendations/experience as to brands of hyper and forged pistons ...
What about flat tappet hydro street cams ??
Thanks -- The TAZ
Old 05-16-2013, 05:12 PM
KB Hypereutectics are the only ones I would consider using.
For forgings, you can go with Speed Pro/Sealed Power, SRP, Ross, J&amp;E, the list goes on. Note that some forgings are more suited for race applications in regards to material and ring choice. The Sealed Power/Speed Pro's have been around forever, and there are a few well-known issues you need to watch for such as dome to chamber interference.
If you wanted to step up to a high quality street-type forging, I would recommend Autotec pistons. They are a little more money, but they offer several nice features &amp; options not offered on &quot;off the shelf&quot; components.
For a camshaft, I would need to know all the specifics of your build, and as I don't want to derail the OP's thread, please shoot me a PM or an email and we'll go from there.
Old 05-16-2013, 06:10 PM
How about Wiseco, do like them Eric?
Old 05-16-2013, 06:59 PM
Very high quality pistons as well.
