Old 06-05-2013, 09:31 PM
Brucebodyman Brucebodyman is offline
Default Found LS-6 CRR what's most I should pay
Found an LS-6 known about it for years. Havent seen it in years. Going to look at it tomorrow. Here's what I know. CRR code correct intake. No distributor no carb. Not sure if water pump is correct if starter is correct or if it has correct exh. Manifolds. So let's assume it's just long block engine sitting there that's never been apart and not blown up. What are your thoughts on value. My car is a CRV code 4 speed.. I do have date code correct 512 block. Wondering what would be better piece together what I have or use the CRR motor
