Old 07-07-2013, 01:55 PM
MosportGreen66's Avatar
Default 1969 Camaro Brake Calipers
Hi All,
What is the part number for 1969 Camaro single piston front calipers for Super Sport applications? Looking for an explanation on how to decode the date too.
Thanks,
Old 07-08-2013, 12:33 PM
Default Re: 1969 Camaro Brake Calipers
Any help?
Thanks,
Old 07-08-2013, 12:58 PM
Dan:
I think 5473510. It takes up two lines like this:
5473
510
IIRC they use the same number left and right, but the machining is different so that the hose will attach at the top when installed left or right.
I don't remember seeing a year casting code, only a day of the year. I could be wrong on this one.
I may have an extra set sitting around somewhere that I can check. As a last resort, if no one has this info, I can remove a wheel on my car and check.
Old 07-08-2013, 01:09 PM
1969L78Nova 1969L78Nova is offline
Yenko Paid Member
That's the correct number see
Team Camaro site:
http://www.camaros.net/forums/showthread.php?t=62358
Old 07-08-2013, 02:28 PM
Here are pics of mine
Thanks,
Old 07-08-2013, 03:13 PM
I have always known them to use the 633 caliper like Dan has pictured. I believe the date code is a simple Julian code so the one pictured would be the 303rd day. No year is provided.
67 Camaro RS/SS 396 Original Drivetrain
70 Chevelle SS 396 Convertible Original Drivetrain
70 Chevelle SS 454 LS5 Survivor Original Drivetrain
70 El Camino SS 396 Original Drivetrain
65 Impala 396/425
65 Triumph TR4 Original Family Owned
Old 07-10-2013, 12:14 AM
I think the 510's are replacement calipers.That is what i have on my (Z).Dan,i would say yours are 100% correct.
Old 07-10-2013, 02:31 AM
CamaroNOS CamaroNOS is offline
The "303" number is the Julian casting date of that specific caliper.
The actual caliper assembly date is stamped on the underside of the caliper (see the photo below), next to the hole for the disc brake retainer pins.
Hope this helps.
