Old 08-04-2013, 02:31 AM
all_about_cars's Avatar
all_about_cars all_about_cars is offline
Default what coil spring
Replaced front coils on my 69 camaro last year with a set from heartbeat city #3955711-el. The car sits to low for what I would like. I have 14x7 torque thrust and they rub front fender. Any suggestions? I also replaced the rear at same time with the correct multi leaf. I like the rear and would like the front sitting correct. 1969 camaro v8 4 speed p/s p/b no a/c but is an rs. Thanks Eddie
Old 08-04-2013, 02:45 AM
Default Re: what coil spring
Some good discussions on spring selection for a first gen camaro over at camaros.org.
Sounds like you need to raise it up more than a 1/2 inch. However, if you think 1/2 inch would do it for you, I would suggest a pair of these:
http://www.ebay.com/itm/1964-81-CHEVELLE...r#ht_2095wt_854
I have a pair in my car. Needed them to fine tune. I used a pair of springs out of a big block El Camino, then cut off either one or two coils (sorry, can't remember as i did that in 1977). I still have the original Z/28 springs, but they sit a little high for my taste. However, I can put them back in any time I want. That is why I cut up the El Camino springs.
The 3/8 spacer will take the overall height up about 1/2 inch.
If you need to go higher, I would suggest finding someone who has a car that sits how you like, and see what spring they used.
Good luck.
Old 08-06-2013, 02:57 AM
enio45 enio45 is offline
talk to the guys at eaton springs, tell them what you want to do and what height your looking for and they will make them for you....I did 3 sets for a 68Z, from several vendors including HBC and no one is sure what they are sending you....very frustrating event for me, eaton , one converstation and they nailed it.
nothing special, just stock ride height...how hard can that be?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 08-06-2013, 03:24 AM
you would think not to hard by now Ed wouldn't you? They all had plenty of time to get it right.
Old 08-06-2013, 02:26 PM
You are correct, Sam, you would think this would be easy, but I have heard the same stories for 20 + years. And it isn't just getting the height correct. The height can be right, but the spring rate too soft, and it doesn't handle well at all.
Old 08-07-2013, 12:20 AM
Thanks guys I appreciate your abvice. I was lucky to be at the street rod nats this weekend here in town and talked to Eaton in person. They were very helpful. Hopefully second times a charme. Thanks Eddie
Old 08-07-2013, 03:13 AM
Glad it worked out - so far!
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 08-07-2013, 01:22 PM
Bob Harris (Camaro Specialties) has springs for all four corners now, he guarantees the car will sit correctly if you provide him with the model and options.
James
mhm1966 (08-05-2022)
Old 12-17-2013, 12:54 AM
BARRY BARRY is offline
I did the same thing bought 1969 Camaro hg springs for a 427 car.. from heart beat car sits on the ground
Barry Allan
Old 12-18-2013, 10:40 PM
miket1 miket1 is offline
Send a message via ICQ to miket1
It looks like the front needs to be raised at least an inch, the rear looks pretty good
69 Z28 Burgandy
