Go Back   The Supercar Registry > General Discussion > Buick
Old 08-11-2013, 12:55 PM
Double_Nickle Double_Nickle is offline
Default 1955 Buick
I have a 1955 Buick Super with a 322 Nailhead. One of the valves stuck a few days ago. Any suggestions on getting it unstuck?
Old 08-16-2013, 03:40 AM
Guest
Posts: n/a
Default Re: 1955 Buick
A stuck valve usually means a siezure of the valve stem to the valve guide. Probably have to pull the head.
Old 08-17-2013, 03:49 PM
Pull the valve cover and ensure the cam isn't rounded.
IF the valve is stuck open drip some marvel mystery oil down the stem, then take a rawhide mallet and rap the valve a few times to see if it will seat itself or if there is another issue such as galling or bent stem etc etc.
Old 08-17-2013, 10:51 PM
68z28kk 68z28kk is offline
If the car has been sitting for 10 months or more and the valve stuck on initial start up I would look for varnish in the fuel. Non leaded fuel turns yellow the longer it sits and will stick a valve very quickly. It takes carburetor cleaner or lacquer thinner to cut the varnish on the valve guides but with some time and technique it can be unstuck without pulling the head.
If this is the scenario that occurred I can explain how to unstick it if it wasn't bent from piston contact after it stuck. Clint
Old 09-30-2013, 02:03 AM
the car actually sat for 3 years before I got it being started randomly. I drove it for 2 weeks before it stuck. Have tried marvel mystery and a few other things. Have resigned to pulling the head as soon as time permits. Can't find a mechanic in the area to do it for me and my time is limited since I work 84 hours a week. Thanks for the input.
Old 09-30-2013, 02:30 AM
Lynn Lynn is online now
Two door hardtop? Not that it matters for this issue. I just really like the 55 Buick Special. Would have bought a really nice black and white one a few months ago if I did't have too much going right now.
I agree with James. Before you pull the head, give it a few light taps with a rawhide or even a plastic mallet.
