Old 01-16-2014, 01:43 AM
Default Stewart Warner Pedestal Tachs and Monitors
Stewart Warner Pedestal Tach and Monitors for sale:
67-68 Yenko Style Pedestal Tach. Tested and Working: $475
8,000 RPM Greenline(69 Yenkos). Tested and Working: $550
8K RPM Standard Face Tach. Tested and Working $375
10K RPM Standard Face Tach. Tested and Working $375
9K RPM Wrinkle Finish Tach. Teested and Working $250
NOS 7K Wrinkle Finish Tach. $325
NOS 9K Wrinkle Finish Tach. $375
NOS 8K Standard Face Tach. $525
NOS 6K Greenline Tach. $425
These tachs all require ignition monitors to be used safely. I also have monitors availble:
990A, used with electronic ignition. NOS $275 Used $150
990B, used with points ignition and correct for Yenko cars. NOS $400. Used$275
990D, used with points and CD ignition. NOS $325. Used $200
These pictures are right out of storage. If you would like more pictures of any item please let me know and I will clean and take better pictures of the items you would like to see.
I also have other non working pedestal tachs if you would like one a bit cheaper. The tachs are usally broken due to a bad capacitor caused by using the tach without a monitor. There is a guy who just had circuit boards made for these tachs and is replacing the original board. This eliminates the need for the monitor. He is selling the board for $125 and $50 more if you want him to install it.
Thanks,
Jason
