Old 03-07-2014, 06:27 PM
GaryC's Avatar
GaryC GaryC is offline
Default Traction bars and cable support bracket.
Anybody using traction bars now have the emergency brake cable installed as well or no? My Z came with bars when I first bought it. I removed them and installed OEM shock plates but never had the support brackets to reinstall. I'm in the process of locating these brackets and want to install the bars back once I locate a set and wondered if this would be an issue with the bars.
For my 69 Z in the pic below.
Gary
Old 03-08-2014, 02:55 AM
Default Re: Traction bars and cable support bracket.
I have never removed my emergency break cables Gary.
Old 03-08-2014, 03:20 AM
GaryC's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: [email protected]</div><div class="ubbcode-body">I have never removed my emergency break cables Gary. </div></div>
Hi Sam, I was asking about the support brackets not the cables. Do you still have the support brackets to hold your cables in place with your traction bars installed or did you remove them? I'll be installing those traction bars I bought over the winter and wanted to know if anybody kept them on or removed them when they removed the OEM shock plates to install the bars. I never realized until now my support brackets are missing so I'm looking for a set to put back on.
Gary
Old 03-08-2014, 05:30 AM
Dicky's Avatar
Dicky Dicky is offline
Gary, I put a set of Ansen Ground Grabbers on my '69 Z28 in probably 1973 so it has been a while. I do not recall ever removing any E brake cable brackets. [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
DH [img]<<GRAEMLIN_URL>>/flag.gif[/img]
Dicky
Old 03-08-2014, 06:14 AM
GaryC's Avatar
It must have been a common thing to remove them when traction bars were installed and then when the bars were removed to put the OEM shock plates back on those support brackets never made it back on. I've looked at a lot of pics of Camaro's on-line the past few weeks and have yet to see any with them on. Those brackets seem so easy to remove and get lost.
Gary
Old 03-08-2014, 02:37 PM
Tommy Tommy is offline
I threw my brackets away. not needed.
Tommy [img]<<GRAEMLIN_URL>>/[/img]
Old 03-08-2014, 03:01 PM
NO brackets Gary!
Old 03-08-2014, 05:02 PM
GaryC's Avatar
OK...so it must of been the common thing to do then. I was just curious since I have seen many with them missing.
Gary
