Old 04-17-2014, 05:12 PM
XXXGoldL34M20's Avatar
Default 1970 Chevelle CD2 Washer Fluid Monitor System
CD2 Fiber Optic Washer Fluid Monitor System that is complete. A one year only option in 1970. This is the system that the positive wire goes through the firewall and gets hooked up at the fuse box.
Washer bottle is the Correct Square Bottom "No Part Number" variation and has some aging with yellow toning and no cracks. Bottle has been cleaned properly with an SOS pad and treated with a plastic cleaner, it is ready for installation with no cleaning required.
System Includes Uncut FIBER OPTIC CABLE, Factory FIREWALL GROMMET, Under dash WASHER FLUID MONITOR EYE with HARDWARE, BOTTLE CAP With RIBBED HOSE + SUCTION FILTER, FLOAT LIGHT ASSEMBLY With LIGHT COLOR INDICATOR STICK, FENDER GROUND CLIP, METAL CLIP That Holds The Fiber Optic Cable Under The Dash. Wires are uncut but the end of the Positive wire did not have a connector so I added a Female End to hook up to the fuse box were it is marked on the very bottom left corner "LPS" (Lamps) or you may take it off and use a slice connector hooked to the wiper switch.
Unit has been tested and works like it should and is in excellent condition. System comes shipped completely assembled, except for the Washer Fluid Monitor Unit which you will hook up at the end of the installment. Washer Fluid monitor has a broken tab missing underneath the unit but you will not see this when installed under the dash.
$350<span style="color: #FF0000">*SOLD*</span>
