Old 04-17-2014, 10:47 PM
Tommy_Mathison Tommy_Mathison is offline
Default Camaro Z/28 LT1 Muncie 1st-Design Flywheel Cover
Assembly line correct GM first-design small block Z/28 & LT1 flywheel inspection cover plate for use with the #403 bellhousing. (All with manual transmission and 10.4" clutch)
This is the correct FIRST DESIGN cover without the die-cut fingers around the rear main. Very tough to find. Super clean rust-free AZ part.
$125
Tommy Mathison
