Old 06-26-2014, 11:08 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Default L82 WIW
any thoughts on the value of a 1974 L82 long-block? over $500?
I ain't nobody, dork.
Old 06-27-2014, 04:13 PM
Fast67VelleN2O's Avatar
Default Re: L82 WIW
What's it out of specifically? Corvette? Camaro? Auto or 4 Speed? Honestly I think around $400 give or take a few bucks is spot on. Trying to find the right buyer would be the hard part.
Day 2 is Life.
Old 06-27-2014, 05:21 PM
Tracker1's Avatar
Default Re: L82 WIW
'74 Z28 auto. - CLK
Old 06-27-2014, 05:33 PM
Default Re: L82 WIW
Car known dead or MIA?
Old 06-27-2014, 06:55 PM
Tracker1's Avatar
Default Re: L82 WIW
MIA
just pulled it out of a black '71 RS Z28 we got out of New York 10 years ago.
Old 06-27-2014, 07:49 PM
WILMASBOYL78's Avatar
Default Re: L82 WIW
If the components are original it should be a 4 bolt #010 block, heads will be #881 castings with 2.02/1.60 valves[74cc chambers] and it will have a steel crank and forged rods. Seems like a good platform to build from provided there are no issues with the individual pieces. There are probably lots of small blocks floating around...but if it is all together in one place that helps. $500 would be a great price...I'm sure you could get more...especially if it has all the tin and bolt on stuff.
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 06-27-2014, 09:41 PM
92646 92646 is offline
Default Re: L82 WIW
If that long block was closer to me I would be all over it. The engine had everything a 350LT-1 had except the high compression pistons, aluminum intake, solid lifter cam and the Holley. I had a L82 in a 1973 Z/28 with a close ratio Muncie and 4:10 posi rear end. I surprised allot of big block Chevelles back when I was sixteen years old and that engine never gave me a bit of trouble. If I remember right it also had screw in studs, guide plates, pink connecting rods and forged pistons.
Old 06-28-2014, 04:37 AM
mssl72's Avatar
mssl72 mssl72 is offline
Default Re: L82 WIW
What's the VIN? I'm curious to see how close it is to mine.
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 06-28-2014, 11:18 AM
Tracker1's Avatar
Default Re: L82 WIW
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: mssl72</div><div class="ubbcode-body">What's the VIN? I'm curious to see how close it is to mine. </div></div>
146254
Old 06-28-2014, 11:51 AM
Tracker1's Avatar
Default Re: L82 WIW
K-14-3 date code
