Old 08-17-2014, 12:05 AM
njsteve njsteve is offline
Default A/C hose rebuilding service?
I need to get one of the unique A/C hoses rebuilt for my Grandfather's 1971 Lincoln Continental. The hose was rubbing against the master cylinder, and wore a hole in the rubber section of the hose. These cars were unique in that they used a GM A6 compressor and the complete Frigedaire A/C setup just like any 1970's GM car. No one makes the replacement hoses for them.
Does anyone out there recommend a specific shop that can replace the rubber hose section and reattach the ends (or replace them)?
Thanks.
Here's the link to the car:
https://www.yenko.net/ubbthreads/ubbthrea...-a-l#Post539151
Old 08-18-2014, 12:16 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Default Re: A/C hose rebuilding service?
I think any of the vintage A/C guys can rebuild hose assemblies. Here is Classic Auto Air's website
http://www.classicautoair.com/GM_OEM...ml#restoration
Jake
Jake Dykstra
Dykstra Motorsports
Old 08-18-2014, 02:20 PM
VintageMusclecar's Avatar
Didn't NAPA stores make & repair AC & hydraulic hoses at one time?
Old 08-18-2014, 03:17 PM
They still do. Just take them your old hose. The fittings probably won't look like the originals though. Just a good functional repair that fits.
Verne [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 08-18-2014, 05:53 PM
Enoch Enoch is offline
Banned
Steve, go to industrial rubber supply 7 chimney rock road just around the corner from where I used to be Across the street from UPS. They can make any hose you need on the spot while you wait. Rich.
Old 08-18-2014, 10:04 PM
Thx Rich. I think I may have checked with them in the past and they do hydraulic lines but not A/C lines. I will recheck with them tomorrow and see.
Old 08-18-2014, 10:10 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: VintageMusclecar</div><div class="ubbcode-body">Didn't NAPA stores make &amp; repair AC &amp; hydraulic hoses at one time? </div></div>
Napa only seems to do hydraulic hoses now. They said they had too much trouble with the A/C fittings leaking.
Old 08-19-2014, 09:19 PM
I called Industrial Rubber and they can make their own working version of an existing A/C hose but only if they have the proper ends in stock. They also use an industrial hose that is much thinner than the thick original hose. The real deal-killer is that they can't reuse the uniquely bent ends on the original hose. So that rules them out.
I sent the hose to Classic Auto Air in Tamps this morning. They will give me an estimate when it arrives.
