Old 02-19-2015, 01:24 AM
Default High Temp Primer for Engines?
Looking for a high temp etch primer to paint an engine with. Does anyone have any recommendations / experiences? As much as I would like to have it painted from a gun, its looking like rattle can will have to suffice.
Thanks in advance,
Dave
Old 02-19-2015, 03:46 AM
Default Re: High Temp Primer for Engines?
If you're going to shoot it through a gun. I like ppg dp70lf.
Old 02-19-2015, 11:19 AM
m22mike's Avatar
m22mike m22mike is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Schonyenko2</div><div class="ubbcode-body">If you're going to shoot it through a gun. I like ppg dp70lf. </div></div>
X2, [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] I would forget the etch primer and etch the block. Then Epoxy primer, lightly reduced.
Old 02-19-2015, 05:45 PM
Billohio Billohio is offline
KBS makes a high temp primer for use under there engine paints in a spray can. I used it but not gotten the engine hot yet
Bill
Old 02-22-2015, 06:34 PM
Thanks guys. I need s spray can primer. I will look into the KBS.
