<object width="425" height="350"> <param name="movie" value="https://www.youtube.com/v/X5XBsSxfrzc"></param> <param name="wmode" value="transparent"></param> <embed src="https://www.youtube.com/v/X5XBsSxfrzc" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> </embed></object>
The video was not the final result, but as you can see the ZL1 is very responsive. Here is a very conservative option, we only increased the boost approx 2 lbs avg, the headers change the sound characteristics of the car, great drivability and your engine will last a good long time : ) plus you can easily up the power with just another pulley change / tune. 2" Kooks Long Tube Headers Off road connection pipes Roto Fab CAI ATI Damper 10% Overdrive Pulley ID 850 Injectors Ported Throttle Body 160 deg Stat NicKey custom tune 93 Octane Pump Gas ![]() |
