Old 03-16-2015, 05:00 AM
68 DANA's Avatar
68 DANA 68 DANA is offline
Default 68 camaro Inspection Paint Color and Locations
Are there any publications, documentation or information available that identifies the <span style="text-decoration: underline">correct</span> paint color, factory inspection locations, markings on the chassis and engine bay? Also looking for any information on the proper color (i.e. black) an sheen for the engine accessories.
-Dave
"Day 2 Grocery Getter"
68 SSRS 427 Dana Camaro
Old 03-16-2015, 11:47 PM
Default Re: 68 camaro Inspection Paint Color and Locations
You can get McNeish's book it has colors, otherwise you would have to mix individual colors to match what you find.
As far as inspection marks, most of what you see on restored cars is no where close to what is found on original unrestored cars.
The best suggestion is to try to duplicate what you find when you carefully clean your parts.
Survivors, restored cars, &amp; other photos
Old 08-23-2015, 06:25 AM
68 DANA's Avatar
Any other publications out there besides Jerry MacNeish's book?
Old 09-02-2015, 04:55 AM
68 DANA's Avatar
Still searching.
Old 12-01-2015, 04:01 AM
68 DANA's Avatar
Does anyone know if there are similarities between the markings between the Camaro and the Firebird? Apparently there are specs on Firebirds. [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
-Dave
Old 12-01-2015, 04:41 PM
70 copo 70 copo is offline
Inspection marks for Camaros and Firebirds produced at Norwood are explained in detail in Echoes of Norwood....
Old 12-01-2015, 08:24 PM
ZLP955's Avatar
ZLP955 ZLP955 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 70 copo</div><div class="ubbcode-body">Inspection marks for Camaros and Firebirds produced at Norwood are explained in detail in Echoes of Norwood.... </div></div>
Were there any differences in Camaro inspection processes/markings between 68 and 69 (when Firebird production began mid-way through the 69 MY)?
Tim in NSW, Australia
Old 12-01-2015, 10:56 PM
I am pretty protective of the book research but for the sake of giving you an answer here is an excerpt from the book &quot;Echoes of Norwood&quot; © 2013 Philip Borris
<span style="font-style: italic"><span style="font-weight: bold">&quot;The audit report was structured to capture quality deficiencies known internally as “classed demerits”. Defects that were identified as part of the audit were assigned class “A”, “B”, “C” and “D” respectively. The class “A” defect had a demerit value of 20 and was considered to be one that if left uncorrected “would or could adversely affect the personal safety of the occupants or the public in general”. When a class “A” defect was encountered on an audit an immediate check was made on the entire production system. The first step was to put a 100% check into effect at or as near as possible to the specific production operation involved. <span style="text-decoration: underline">The evidence of the of the 100% check remained on the affected components of the cars typically as an inspector’s mark with a crayon or a daub of paint indicating that the deficient assembly operation had been performed properly to the production specification. The second step is to then check twenty-five completed vehicles for the continuing presence of the defect. This check begins at the point where the 100% inspection was established and covers the twenty-five units that had just been assembled&quot;</span>. </span></span>
There was little rhyme or reason for inspection marks and as you can see why as they were the random product of the quality process.
Attached is the quality Metric page from June 1969 Enjoy!
Old 12-05-2015, 02:41 AM
68 DANA's Avatar
Phil,
Thanks for information....much appreciated......[img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
-Dave
Old 12-05-2015, 11:33 AM
Thanks... the in plant Quality Metrics really show the actual period correct post assembly condition of these cars...304 discrepancies out of 400 cars examined with visible dirt in the paint.
