Old 07-08-2015, 02:46 AM
scuncio scuncio is offline
Default 1967 GTO tire size
Hi all,
I just bought a cool survivor-ish '67 GTO HO convertible. Looking to buy a set of redline radials from Diamond Back and run a set of 1960s TTDs I've had stored away. I thought I wanted 225/70 15s, but after seeing the car in the link below (has the 225/70-15s on the front) I think they are a little tall. What do you folks think would be an ideal size?
Thanks!
https://myclassicgarage.com/marketpl...3/media/911151
Old 07-08-2015, 11:43 AM
bluel78 bluel78 is offline
Default Re: 1967 GTO tire size
I think you should talk the owners of that car to ditch the master crafts for redlines. 225/70-15 would look good and would fill the wheel wells like the designers wanted.
Old 07-08-2015, 01:11 PM
GTO_DON GTO_DON is offline
225-70's are way too big for that car. Do yourself a favor and keep the 14's on it.
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
Old 07-08-2015, 01:52 PM
Thanks guys. Don, if 225/70 is too big what would you recommend?
Old 07-09-2015, 12:41 PM
novadude novadude is offline
A 235/60R15 is 26" tall - pretty close to the stock tire height. Works well on a 7" wheel.
Old 07-09-2015, 02:01 PM
PxTx's Avatar
PxTx PxTx is offline
I think a 235/60 15 may be too wide for an early A-body, up front that is.
Paul III
Old 07-09-2015, 07:57 PM
235/60R15 section width is 0.393" wider than the 225/70 proposed above - tread will be a bit wider, and the tire will be shorter though. I know they fit stock height 69-70 a-bodies with no issue at all using a 15x7, typical 4.25" backspace wheel. Never tried on a 64-67 though.
