Old 09-18-2015, 03:05 PM
Craig_Maiorana's Avatar
Craig_Maiorana Craig_Maiorana is offline
Default 1968 Camaro factory dash color?
I am just putting it out there to see if I can get an answer for my buddy. He is restoring his 68 and we're trying to get a bead on what would be the correct shade of black for the dash. Any help would be appreciated.
[img]<<GRAEMLIN_URL>>/dunno.gif[/img]
I like cars more than I like people .....
Old 09-18-2015, 06:23 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Default Re: 1968 Camaro factory dash color?
This should help you..
http://www.camaros.org/forum/index.p...sg5323#msg5323
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mark</div><div class="ubbcode-body">
Top of dash is 0 gloss black Ditzler code DIA-9317, front of the dash was semi gloss black Ditzler code DIA-9266. The top of the dash usually has a suede additive in it that gave it kind of a slightly textured look. The vast majority of the painted interior parts were painted with the semi gloss paint. Things like rear window defogger grilles, speaker grilles, console compartment door, and the corner escuthion (trim pieces) on the rear window were about the only other flat black items.
</div></div>
Old 09-18-2015, 11:15 PM
Thank you a ton Darrell ... I knew it had been discussed before and I also knew someone had that info stored in their memory banks. Thank you again
Old 09-19-2015, 12:31 AM
cook_dw's Avatar
If it's something about '68 Camaros I try to stay on top of it.. [img]<<GRAEMLIN_URL>>/grin.gif[/img]
