Old 01-10-2016, 12:48 PM
ALLZS ALLZS is offline
Default ASSEMBLY LINE CORRECT SUBFRAME BUSHINGS
DID OR WAY & HOW DID THE FACTORY TAPE THE BUSHINGS TO THE SUBFRAME
Old 01-10-2016, 10:59 PM
camaromb camaromb is offline
Default Re: ASSEMBLY LINE CORRECT SUBFRAME BUSHINGS
On the original cars I've seen the tape was used to cover the body holes over the rear bushings, the bushings were not taped to the subframe.
Old 01-10-2016, 11:35 PM
enio45 enio45 is offline
yep what mark said
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 01-11-2016, 02:01 AM
m22mike's Avatar
m22mike m22mike is offline
Rich
As stated by Mark there was tape over the rear sub frame holes. This was placed there during a body water leak test. It is a general misconception that the bushing were taped in place.
Here is a good shot of the that tape, sticky side up. At least on Camaro.
Old 01-11-2016, 02:19 AM
THANKS FOR ALL THE INPUT THANKS FOR THE PICTURE
Old 01-12-2016, 09:47 PM
Scott69Z Scott69Z is offline
What kind of tape was used on the floor?
Scott
Old 01-12-2016, 10:14 PM
m22mike's Avatar
The ones I have had look like 2" black masking type tape.
Mike
