Old 02-29-2016, 02:46 PM
BillD BillD is offline
Default 454 LS6 cam selection
I am building a 454 LS6 to use in my Chevelle. For a cam I was thinking of using a Comp Cams 294S. Here are the specs: http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=458&sb=2. Good choice or should I look elsewhere? I do want to stick with a solid lifter cam. Not interested in a roller or hydraulic. Thanks for the help
Old 02-29-2016, 03:12 PM
earntaz earntaz is offline
Default Re: 454 LS6 cam selection
Have you looked at the Comp Cam NOSTALGIA PLUS? TAZ
Old 02-29-2016, 04:09 PM
VintageMusclecar's Avatar
Manifolds or headers?
FWIW, I wouldn't use a COMP flat tappet cam if you held a gun to my head.
Old 02-29-2016, 04:32 PM
Headers, otherwise pretty much stock. Thank you for the information. Any advice you could offer would be appreciated.
Old 02-29-2016, 04:39 PM
Alss's Avatar
Alss Alss is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: VintageMusclecar</div><div class="ubbcode-body">Manifolds or headers?
FWIW, I wouldn't use a COMP flat tappet cam if you held a gun to my head. </div></div>
X2
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 02-29-2016, 04:45 PM
What transmission (/converter) and rear gear?
What are your performance goals?
Do you care about idle quality?
Old 02-29-2016, 05:12 PM
M-22 with 220 FIRST, 4.11's, It gets occasional street use, probably never going to see track use. I don't care about idle quality. Thanks again.
Old 02-29-2016, 09:40 PM
Bill;
Check your PM's.
Eric
Old 02-29-2016, 09:52 PM
XXXGoldL34M20's Avatar
Used the Lunati #20202 for two LS6 rebuilds in a row.
IMO a great cam. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
