Old 03-15-2016, 04:50 AM
Chevyfever Chevyfever is offline
Default L78 intake
I have an L78 intake originally from 68 camaro,has repair in 1 bolt area and a damaged bolt hole at thermostat housing.
Any comments, if this is worth trying to repair or should it be discarded?
Bernard
Old 03-15-2016, 05:51 AM
Default Re: L78 intake
I think any factory aluminum intake is worth saving. Many not be usable for high end applications but there is likely a home for any usable intake.
Jason
Old 03-16-2016, 01:23 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SuperNovaSS</div><div class="ubbcode-body">I think any factory aluminum intake is worth saving. Many not be usable for high end applications but there is likely a home for any usable intake.
Jason </div></div>
Thanks for the response Jason.
Bernard
Old 03-16-2016, 01:59 AM
I agree - plus I would also add.....that I would much rather have a repaired original over a fake snowflake intake [img]<<GRAEMLIN_URL>>/thumbsdown.gif[/img]
Old 03-16-2016, 02:25 AM
P.J. P.J. is offline
Saving this intake is a good idea. You can have it welded by a professional
aluminium welder. then depending on the damage threads, you can carefully
re tap the holes.
on the intake bolt holes you can work the extra access weld by a rotary file
If you were close to me I would help you return this intake to almost orig cond
Go for it
PJ
Old 03-16-2016, 04:57 PM
L78steve L78steve is offline
Jerry M.Does a good job with intakes so does Jeff Dotterer.
