Old 06-20-2016, 02:20 PM
Default Black LS-6 Chevelle No Reserve
Good looking car that Ends soon.
http://www.ebay.com/itm/Chevrolet-Chevel...em=182170965420
Old 06-20-2016, 02:59 PM
Zedder's Avatar
Zedder Zedder is offline
Default Re: Black LS-6 Chevelle No Reserve
Isn't $70k cheap for this car?
Mark
Old 06-20-2016, 03:15 PM
I think the shifter on the column will hold it back a bit. Cool car though.
Old 06-20-2016, 03:27 PM
COPO COPO is offline
Protect-o-plate seems suspect to me. Don't like the axle code.
Old 06-20-2016, 03:29 PM
BLACKLS5 BLACKLS5 is online now
Or the transmission code...
Old 06-20-2016, 05:41 PM
Your both right.I didn't see that protecto plate photo earlier.
Both the trans & rear are not coded correctly for an LS-6.Those 2 were specific to that engine.
His trans says L-78/LT-1.
His rear says 1971/72 3.31 Chevelle.
I emailed the seller asking him about these 2 issues.
Hopefully he'll reply.
Old 06-20-2016, 05:46 PM
Fast67VelleN2O's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mr70</div><div class="ubbcode-body">
</div></div>
How do you get that from the rear end code? If it was 1971, 1972, it would be CCF. All rear codes had the C before them starting in the late 1969 model year.
Day 2 is Life.
Old 06-20-2016, 06:01 PM
Just CF was used in 1964-65-66-67-68-69 Chevelle.
CCF was new for 1970,and CCF was a 1970 L-34 coded Chevelle/Elco &amp; used in Monte too.
1971-72 Chevelle went back to CF.
Old 06-20-2016, 06:29 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mr70</div><div class="ubbcode-body">Just CF was used in 1964-65-66-67-68-69 Chevelle.
</div></div>
Sorry, I wrote that wrong, if 1971, 1972, it would have the C following the code, such as CFC or KDC, RUC, etc.
Day 2 is Life.
Old 06-20-2016, 06:35 PM
And that second following C in your example Matt actually stood for the assembly plant code,(Buffalo),where as the 1970 CCF did not,(stood for Chevrolet),and had it's assembly plant code stamped further down.
