Old 07-29-2016, 02:47 PM
XXXGoldL34M20's Avatar
Default LT1 GM 2182 Camshaft Camaro Z28 Corvette 70 71 72
The "2182" Casting number identifies this camshaft as GM part number 3972182. A Solid Lifter Camshaft for 1970 1971 and 1972 Camaro Z28 or Corvette with the 350 LT1 Small Block Motor. Also a great fitting cam for the earlier 302 or 327 Solid lifter Hi-Po motors used by Corvette, Nova or Camaro. Cam is in used shape but with little to no wear. Cleaned and polished by a machine shop and ready for installation.
Cam Specs >>> The duration at lash point in degrees (intake/exhaust) is 300/312; duration at .050" tappet lift (intake/exhaust) is 242/254; and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 435/455. Valve lash is 024/030 and lobe centerline is 116 degrees.
$125 with free shipping to the lower 48 States.
<span style="color: #FF0000">*SOLD*</span>
Old 07-29-2016, 10:18 PM
Default Re: LT1 GM 2182 Camshaft Camaro Z28 Corvette 70 71 72
I will take the cam. Sent you a pm.
Paul
Old 07-30-2016, 01:21 PM
Payment sent.
Paul
