Old 08-09-2016, 02:49 PM
XXXGoldL34M20's Avatar
Default BB 396 427 454 Rockers-Studs-Lockers-Pivot Bal Set
Complete set of used High Performance Rocker Arms (Not sure if those are a "L" stamp or "F" Stamp), Original GM Rocker Studs, Slotted Pivot Balls and Top Bolts with keepers/locks.
This is a matching set that came off a running 1968 Camaro with a L78 396 375 HP Solid Lifter Motor. No issues what so ever on this set as they can be used again. When they were removed from the engine, I matched all the separate units together.
These will fit under the stock Valve Covers.
$225 with FREE Shipping to the lower 48 States.
