Hi Guys,
I am restoring a 67 435HP coupe that we are bringing to MCACN and I am looking for some very tough to find parts. If anyone can help or has any leads, it would be much appreciated. 1) NOS ignition shielding 2) NOS LH outer window fuzzie 3) NOS fan belt 4) Lower radiator hose (good used with real stamping) 5) NOS gas pedal 6) NOS antenna ground plate 7) REAL OE Coil #1115263 8) NOS assembly line u-joints 9) Heater hoses (good used originals w/ orig stampings.) 10) Mint used power window door panels in black. 12) NOS Tri-power Air Cleaner Lid w/ original silkscreened logo on underside. Thanks for your time. Mike [email protected] |
PM sent
Thanks,Joe |
I am adding to the list:
13) NOS TI Ignition harness Thank you! |
Here is an updated list:
1) NOS ignition shielding 2) NOS LH outer window fuzzie 3) NOS fan belt (alternator) 4) Lower radiator hose (good used with real stamping) 5) NOS gas pedal 6) NOS antenna ground plate 8) NOS assembly line u-joints 9) Heater hoses (good used originals w/ orig stampings.) 10) Mint used power window door panels in black. 13) NOS TI Ignition harness 14) Original OEM motor mounts Thanks for the help guys! |
Hi Mike, it sounds like you are really dialing your car in. I am looking forward to seeing it at the show.
Corvette nut since I was a kid. 67 435s and L88s are my favorites |
Thanks Steve!
Here is the latest updated list:
1) NOS ignition shielding 2) NOS LH outer window fuzzie 3) NOS fan belt (alternator) 4) Lower radiator hose (good used with real stamping) 5) NOS gas pedal 6) NOS antenna ground plate 9) Heater hoses (good used originals w/ orig stampings.) 10) Mint used power window door panels in black. 13) NOS TI Ignition harness 14) Original OEM motor mounts Thanks for the help guys! |
1) NOS ignition shielding 3) NOS fan belt (alternator) 4) Lower radiator hose (good used with real stamping) 5) NOS gas pedal 6) NOS antenna ground plate 9) Heater hoses (good used originals w/ orig stampings.) 10) Mint used power window door panels in black. 13) NOS TI Ignition harness 14) Original OEM motor mounts 15) Original flame arrestor hose Thanks for the help guys! |
