Old 10-05-2016, 01:19 PM
Default WTB Original Black Headrests for 69 Camaro
Looking for a nice clean set of original headrests for 69 Camaro with black interior. Prefer a mint set if I can find one.
PM if you have some clean one. Thanks
Old 10-05-2016, 01:29 PM
L78 Fred L78 Fred is offline
Default Re: WTB Original Black Headrests for 69 Camaro
Are date codes important to you?
As the shaft is dated
Best wishes
If dates are not important - Legendary makes a nice reproduction
If they do please send me your contact info and I will see what I can dig up
Unless someone else has something readily available
Fred
[email protected]
610-585-4155
WANTED:
1969 396/375 hp JH Vin N6352xx Mid April 69 block 272 casting
Always looking for dated L78 parts from Jan-Apr 69
Old 10-05-2016, 01:35 PM
bbbentley's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: L78 Fred</div><div class="ubbcode-body">Are date codes important to you?
Best wishes
</div></div>
Might want to make OP aware they changed the angle of the HR in Nov 68 and if they care about correct or original, that may make a difference?
FULL OWNER HISTORY
Old 10-05-2016, 01:39 PM
ALLZS ALLZS is offline
DOES LEGENDARY MAKE COVERS TO RECOVER ORIGINAL HEADRESTS
Old 10-06-2016, 10:55 AM
Thanks Fred,
I have already bought a set of the head rests from Legendary and they aren't that great to be honest. Not quite the same contour along the bottom of the foams nor do they want to sit all the way down in the slides like they should. If I can't find a decent set of originals, I'll work on these and perhaps alter the post (or slides) to make them bottom out. If you look close you can see they are 1/2&quot; proud of the seat and don't drop down properly. I did put aftermarket slides into the cores as the old ones were cracked and might have to look at the slides as well to ensure they aren't contributing to the problem?
Old 10-06-2016, 11:28 AM
KevinW KevinW is offline
Ah, the seats in the pic are Curved neck ones, starting on Camaros in Late Nov 68, but there was some overlap due to stock on hand. http://www.camaros.org/headrest.shtml
I have both curved and straight headrest seats. I have noticed if you try to put curved headrests on straight headrest seats, they do stick up more than normal. But when looking at the slides and plates, I have been unable to notice a difference. Another mystery for future research!
69 327 convertible (driver)
Old 10-06-2016, 01:11 PM
These seats had curved neck headrests originally. The slides were both cracked so I bought a set of repro slides from Camaro Central and new curved neck headrests from Legendary. Once I put the slides in it was immediately noticeable that the headrests stopped short of seating properly. I haven't played around with them yet but may have to if I cannot find a nice set of originals. The old ones were badly cracked and unfortunately I threw them away before checking to see if the slide is the actual problem
Old 10-06-2016, 10:24 PM
Spooky's Avatar
Spooky Spooky is offline
I talked to Legendary at Carlisle in the spring and they told me that interior die would not stick to theirs because of the mold release agent that is used.
Just passing on what they told me.
Scott
69 Camaro RS/SS X22 4speed NOM but working on something special
69 Camaro x11 355 crossram m22 12 bolt 3.73's
Old 10-06-2016, 10:42 PM
chevyman0429's Avatar
So on the Camaro does the headrest have one or two slides per headrest. Iv got a mint set of black headrest that have two slides per headrest. I thought they were from a chevelle bench seat if they will work for you I'd be interested in letting them go.
1969 SS 396 chevelle
1978 chevy shortbed step side
1983 chevy shortbed
1985 chevy shortbed
Old 10-07-2016, 12:29 AM
Camaro has one bar per unit. I think the 2 round bars are for Chevelle and Nova
