Old 11-03-2016, 12:23 PM
camaro1 camaro1 is offline
Default 69 camaro steering column rebuild suggestions
I'm looking to get my standard non tilt column rebuilt, can you guys suggest some one who does this and will repaint it?
Any spray paint recommendations in a spray bomb for the column?
I'm just not sure if I should send it out or clean it up myself and repaint.
Thanks Rich
Old 11-03-2016, 01:00 PM
SS427's Avatar
SS427 SS427 is offline
Default Re: 69 camaro steering column rebuild suggestions
We do them but I could not start on it until after December 1st.
Rick Nelson
Old 11-03-2016, 01:03 PM
earntaz earntaz is offline
How do I find out the date on these columns -- I have one that (I think) came out of a 68-69 Camaro or Nova. Thanks ... TAZ
Old 11-03-2016, 01:08 PM
enio45 enio45 is offline
IF i recall, at the bottom of the black tube there is a date code for the column - stamped into it
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
cook_dw's Avatar
cook_dw cook_dw is offline
67-8 Camaro are the same and 69 is different for Camaro. 9 is when the key went to the column from the dash.
Old 11-03-2016, 02:12 PM
ssl78 ssl78 is offline
The column on a 67 68 are the same but the turn signal switch plug is different on the two years.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 11-03-2016, 02:45 PM
m22mike's Avatar
m22mike m22mike is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: enio45</div><div class="ubbcode-body">IF i recall, at the bottom of the black tube there is a date code for the column - stamped into it
</div></div>
Like this
Old 11-03-2016, 06:47 PM
The column I have (nontilt) is stamped &quot;A2 321&quot;. I also has a separate &quot;13&quot; and &quot;125&quot; ... so do those numbers indicate what it came from? Thanks ... TAZ
Old 11-05-2016, 04:43 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: earntaz</div><div class="ubbcode-body">The column I have (nontilt) is stamped &quot;A2 321&quot;. I also has a separate &quot;13&quot; and &quot;125&quot; ... so do those numbers indicate what it came from? Thanks ... TAZ</div></div>
A mystery?
