Old 12-12-2016, 07:44 PM
Default BBC Water Pump Bypass Fitting
Is there any kind of special tool made for removal and/or installation of the water pump bypass hose fitting in a big block Chevy? This fitting has a slot in the one end, and I'm sure many (if not most)of these fittings have had a large screwdriver used for installation.....but the potential for damage or distortion of the fitting end would seem to make this a less-than-ideal choice.
Trying to remove an old one from a water pump that has been used for years is 'mission impossible' with a big screwdriver. A huge vise-Grip or ChannelLock pliers would undoubtedly work, but would also destroy the fitting. Any suggestions?
Bill Pritchard
Old 12-12-2016, 07:54 PM
earntaz earntaz is offline
Default Re: BBC Water Pump Bypass Fitting
heat -- heat -- heat ... last resort, slide a piece of round stock or a socket of the correct size inside the fitting and use a vise grips. Any damage will be covered by hose when installed and not evident. TAZ
Old 12-13-2016, 12:12 PM
YENKO DEUCE REGISTRY's Avatar
A really large screwdriver (like 24" long!) worked perfectly for me....
Marlin
Old 12-13-2016, 12:33 PM
OK Marlin -- you started it ... I've used a flat end tire tool that I ground down to fit the slots. Used a a large adjustable end wrench to turn tool ... TAZ
Old 12-13-2016, 01:16 PM
Bill,
If you have an old socket you'd sacrifice, find one that is a close fit around the fitting, cut two slots in it, then place a flat piece of steel in the slots that fits into the notches in the hose fitting.
Verne
Old 12-13-2016, 03:32 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Verne_Frantz</div><div class="ubbcode-body">Bill,
Verne</div></div>
Good idea!
Old 12-13-2016, 04:38 PM
X66 714's Avatar
X66 714 X66 714 is offline
There were several socket to adjust the tie rod ends on early Chevrolets, probably other cars also. I bought some on e-bay for cheap...Joe
Old 12-13-2016, 07:44 PM
Big Block Bill Big Block Bill is online now
X-2 I use a &quot;Drag Link Adjusting Socket&quot; for heavy duty trucks.
Bill
Old 12-14-2016, 12:31 AM
Great ideas, everyone....thanks to all who have responded [img]<<GRAEMLIN_URL>>/worship.gif[/img]
Bill Pritchard
Old 12-14-2016, 01:01 AM
Big Block Bill,
That looks like exactly what I need.....checking into one on eBay right now!
Bill Pritchard
