Old 12-14-2016, 01:41 PM
XXXGoldL34M20's Avatar
Default 70 Chevelle Original GM Front Disc Brake Calipers
For Sale >>> "Born With" Single Piston Front Disc Brake Calipers. 5469700 L left & 5469701 R right with original Orange Inked Hoses and original Flow Bolts with double Brass washers. The Casting dates are 3 days apart at J27 and J30 which is September 27 and 30 of 1969. Actual Production Julian Date is 04470 which is February 13 1970.
$200 for the pair and you get everything in the photos. Shipping is Extra at $35 as these are on the heavy side in weight. If shipping is less I'll Refund the difference. Person I bought these from told me they worked fine when he took them off his car and has been sitting with oil in them for 5 years after coming off his LS5 454 SS,(I now drained the oil out) even if there not in working order they are great original cores to rebuild for your Front Disc Brakes.
Paypal &quot;Friends &amp; Family&quot; Option. <span style="color: #FF0000">*SOLD*</span>
Old 12-14-2016, 09:48 PM
luzl78 luzl78 is offline
Default Re: 70 Chevelle Original GM Front Disc Brake Calipers
Danny. Are these the same for my 70 monte 402? I would think they would be. If they are I'll take them. Jeff in nj
Old 12-14-2016, 10:13 PM
SS427's Avatar
SS427 SS427 is offline
There are the same.
Rick Nelson
Old 12-15-2016, 12:04 AM
Pretty sure that letter &quot;J&quot; is a September casting date.
What's the final assembly day &amp; date of each caliper itself?
I can barely make the whole stamping out,it should be either a 5 or 6 digit code stamped on both here.
It'll denote the year @ the end of either one too with a 70 for 1970.
Old 12-15-2016, 01:09 AM
After looking a second time it looks as though I found a pretty clear date code on one of the ears under high magnification of 04470 which is February 13 1970 Julian Date.
Makes sense as the car was built in March from which they came off of. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] All the correct Info is now Updated and edited in the first post.
Old 12-15-2016, 01:20 AM
Yes &amp; that's a specific Delco-Moraine date code format.
The other,if a 6 digit format,would be a Saginaw specific date code of 062170 for June 21st,1970.
