Old 12-20-2016, 11:29 PM
Stefano Stefano is offline
Default 1970 Olds W-30 4 speed Holiday Coupe
1970 Oldsmobile W-30, 4 speed, Holiday Coupe
Total production of all W-30s in 1970 is 3,100 vehicles.
Only 1,032 Holiday Coupes were equipped with 4 speeds from the Factory.
It has been estimated that less than 25% of the 4 speed cars exist today with original engines,transmissions and documentation to prove the 4 speed status.
A broadcast card can prove W-30 option status, color and some options, but will NOT prove 4 speed transmission. You need, a window sticker, line sheet or GM of Canada docs, etc
A 4 speed W-30 is extra special in the OLDS/Muscle car world in that it used a unique long duration 328 degree cam shaft (No a/c or power brakes available) which made more power. This is what helps provide the W-30 that unmistakable chop and lope.
This is unique with OLDS for 1970, in that other Top tier / max efforts Muscle Cars generally had the same engine / cam whether automatic or manual. The Hemi, Stage I, RAIV, LS6, SCJ, AMX etc all used the same camshaft/engine regardless of transmission. In some cases the autos could be quicker car, but not with OLDS and the extra power it produced.
While it is known that the stated 370hp for both the auto and manual were underrated as similar auto cam profile Olds/455s had been rated at 400hp prior, The big cam made more hp at the top end.
Here is one of the few known to exist 4 speeds with documentation and all original drive train as well as an established provenance.
Based on our research, We believe that that this W-30 may have only had three prior owners.
The family we obtained the car from had owned it for approx 22 years.
The car is from Oregon so it is dry and solid with all original GM metal.
It is an original Silver car with, Black stripes and black bucket seat interior and one repaint.
It is a no console car, sport wheel and 3.42 posi
It shows under 16,000 miles and was sold to the previous owners as original miles. They did not dive it much during the 22 years they owned it.
The original numbers matching engine and trans will be freshened and detailed with new clutch and Gardner exhaust as well as fresh and safe Goodyear tires.
Mr. Stephen Minore has also inspected this W-30 and issued his Rocket Report certificate of authenticity.
Price is $110,000.00.
Attachments - The Supercar Registry FD4BDA21-7C5B-476C-91D6-3FF5DB279024.jpeg F6C6262F-5753-4049-B905-B11EBF7DB84D.jpeg DSCN6410.resize.jpg ACE8B567-3115-4034-8E6C-4FEA3311117A.jpeg
