Old 06-04-2017, 02:33 AM
Exclamation New High Performance & Drag Race Parts
Selling Out! Here’s my collection of high performance/drag race parts (all parts are New, unless otherwise noted):
• Holley Dominator 80905HB – 1150 CFM - $1099
• Holley LS 3 Hi Ram & Dual 80802HBX 650HP Hard Core Race Double Pumper Carb Package - $1899
• Big Block Chevy Gasket Package, includes the following (all Mark IV) - $500
o Mr. Gasket 5362 Copper Head Gaskets (2 sets)
o Mr. Gasket 5802 Ultra Seal Head Gaskets (2 sets)
o Mr. Gasket 4405 Cam Change Gasket Set
o Mr. Gasket 5828 Ultra Seal Rectangle Port Intake Gaskets (2 sets)
o Mr. Gasket 5883 Ultra Seal Oil Pan Gaskets (2 sets)
o Mr. Gasket 5912 Ultra Seal Header Gaskets
o Mr. Gasket 5910 Ultra Seal Header Gaskets
o Mr. Gasket 153 Header Gaskets
o Mr. Gasket 5878 Ultra Seal Valve Cover Gaskets (3 sets)
o Mr. Gasket 5862 Ultra Seal Valve Cover Gaskets (3 sets)
o Mr. Gasket 182 Valve Cover Gaskets (3 sets)
o Mr. Gasket 90A Timing Cover Gaskets (2 sets)
o Mr. Gasket 94 Timing Cover Gaskets (2 sets)
o Brodix MG2001 Intake Gaskets (BB-2 Xtra)
o Fel Pro 1804 Oil Pan Set
• Holley Ultra HP Big Block Chevy Mechanical Fuel Pump #454-40 - $449
• XS Power S3400 AGM Batttery + Jerry Bickel Race Cars Custom Mount Package - $339
• Holley Ultra HP Big Block Chevy Mechanical Fuel Pump #454-25 - $289
• Earl's 60 Row Narrow Cooler #26000ERL & Earl’s 1302 Mount Kit - $289
• Earl's 42 Row Narrow Cooler #24200ERL & Earl’s 1302 Mount Kit - $249
• Holley # 12-865 HP Billet 4-Port Fuel Pressure Regulator - $199
• Lunati Chevy EDM Solid Lifter Set - $199
• McLeod Chevy Mini Starter - $179
• XS Power Custom Heavy Duty Trunk Mount Battery Cable Kit - $169
• Crane 13977-1 Pro Series Timing Chain Set. Big Block Chevy - $149
• Holley #8 AN Dual Feed Fuel Line XP Carbs - #34-44 - $129
• Holley # 12-843 HP Billet Fuel Pressure Regulator - $119
• Holley #8 AN Dual Feed Fuel Line XP Carbs - #34-43 - $116
• Moroso Blue Max Spiral Core Wire Spool # 73230 (missing approximately 10-feet) - $99
• MSD #30829 Super Conductor Wire Set - BB Chevy w/ Crab Cap - $89
• MSD #31223 Super Conductor Wire Set - 90-degree boots - $79
• Jerry Bickel Race Cars Chrome Moly Battery Mount Kit - $79
• Holley 260 GPH Dominator Fuel Filter #162-571 - $85
• Street Wire 1/0 Battery Cable Kit (10-feet) Fine Strand Annealed Copper Street Wire - $69
• XS Power Lightweight Trunk Mount Battery Cable Kit # RK2GA-1 - $69
• Holley Billet Regulator Mount - 4150 Carburetor - #20-120 - $70
• Jerry Bickel Race Cars Cable Throttle Linkage Kit - 36-inch - $69
• Small Block Chevy Pro Topline 2.15-Inch Stainless Steel Intake Valves, set of 4 - $59
• Small Block Chevy Pro Topline 2.02-Inch Stainless Steel Intake Valves - $59
• Holley Carb Kit for 4150 Ultra XP Carburetors (I have two of these kits) # 37-1548 - $55
• McLeod Racing 16010 Clutch Release Bearing (GM short configuration) - $55
• Small Block Chevy Pro Topline 1.60-Inch Stainless Steel Exhaust Valves - $49
• MSD Blaster SS Coil #8207 - $49
• XS Power Big 3 1-0 Power Cell Battery Cable Kit #BIG#-RD - $44
• PerTronix 708190 Spark Plug Wires Flame-Thrower Spiral Core Stock Appearing - $44
• Holley 4160 to 4150 Conversion Kit # 34-13 - $44
• Holley Mechanical Choke Cable 45-228 & Mount Hardware # 45-229 Package - $44
• Hooker Headers 3.5" Reducers - #11036HKR - $33
• Moroso Four-Hole Laminated Wood Carb Spacer # 64943 - $30
• Jerry Bickel Race Cars 125 Amp Battery Shut Off Switch - $29
• Hooker Headers Slip Fit 4" Reducers - #11138HKR - $29
• Hooker Headers Slip Fit 3.5” Reducers - #11136HKR - $29
• MSD Chevy V8 Socket Distributor Cap #8437 - $22
• Crane Cams Teflon Valve Stem Seals for 3/8-inch Valve #99822-16 (I have two sets) - $19/set
• Hooker Headers 3.5" Weld On Collector Ring (I have two sets) - #11435HKR - $19/set
• OEM GM BBC 7/16” Rocker Studs (set of 8) - $40
• ACCEL chrome coil (vintage 1971 example), used - $40
• Crane #99893-2 dual valve springs (set of two) – New - $14
• AutoMeter single gauge panel 2-5/8” gauge, new - $15
• AutoMeter dual gauge panel 2-5/8” gauge, new - $19
• Pro Topline 5/16” small block pushrod guide plates, set of four (non-stepped) -- $8
• Aurora Bearing Rod End Package (all are new) - $900 (cost was $1600+)
Includes:
2 RXAB-10T Extra HD 5/8X3/4-16 LH; Teflon
5 RXAM-10T Extra HD 5/8X3/4-16 RH; Teflon
3 RAM-6T HD 3/8X3/8-24 RH; Teflon
4 RAB-6T HD 3/8X3/8-24 LH; Teflon
2 VCM-6 3/8X3/8-24 RH; Teflon
2 VCB-6 3/8X3/8-24 LH; Teflon
1 AB-12T 3/4X3/4-16 LH; Teflon
4 RXAB-8T-3 Extra HD 1/2X5/8-18 LH; Teflon
4 RAXM-8T-3 Extra HD 1/2X5/8-18 RH; Teflon
2 HXAB-8T HD Hi-Misalignment 1/2X5/8-18 LH; Teflon
1 PRM-8T 1/2X1/2-20 RH; Teflon
1 RAB-12T 3/4X3/4-16 LH; Teflon
1 PWB-12T Ύ Spherical Bearing; Teflon
plus…
4 QA1 XMR8 1/2X1/2-20 RH
All prices Or Best Reasonable Offer. Please contact me for photos of any of the above parts or for more detailed info.
