Old 11-07-2017, 06:23 PM
Jamess113's Avatar
Jamess113 Jamess113 is offline
Default 1966 Corvette Grand Sport Replica
SOLD!!!!........1963 Corvette Grand Sport replica, this Grand Sport started out as a real 1966 Corvette and is titled and registered as a 1966 Corvette Coupe. The frame is an original 1966 Corvette frame that is modified to run the 1981-one-piece rear aluminum differential cover and crossmember. Mid-America Grand Sport II front and rear clip, Daytona Hood with custom one off stainless louvers, original Corvette doors with Grand Sport door recess panels, Grand Sport II Dash, Grand Sport head lights and covers, Grand Sport rear end cooler scoop (not mounted) new windshield and glass, new back plastic rear glass, polished OEM windshield trim, PPG paint, Glenn Green, with Gold Sand Poly stripe, frame is gloss black and the rest of the undercarriage is a matted black.
1966 427 casting # 3904351, HI PERF, Casting date J146 Merlin iron heads, Manley valves, 2.190 intake, 1.880 exhaust, Competition Cams Street Roller #11-692-8 .622 lift, Dur @.50 .244, Weind duel plain intake, Carburetor Shop 990 cfm Stage 3 carb, Hooker Super comp 2 1/8 headers w/ 4’ collectors, Hooker Headers 4” side pipes, Accel Electronic mechanical tac drive distributor, MSD 6, Aluminum water pump, Griffin aluminum cross flow 2 core radiator, GM fan and clutch, optima battery.
Transmission M22 2.20 first gear Casting #’s 3925660, 3884685 date code P8T13, late 60’s early 70’s Vintage Lakewood scatter shield w/access panel, Hays 11” street and strip clutch and fly wheel, Hurst Competition Plus shifter.
Brake calipers are Corvette 73-82 2nd design, stock GM rotors, GM master cylinder, custom stainless braided brake hose from frame rail to calipers, factory GM brake shields
PS Vintage Knock Off Grand Sport Wheels with hubs and spinners, custom machined hubs and pin holes for safety pins, 15x8 fronts 15x 10’s rear, BF Goodrich Euro T/A 245 50-15’s front 305 50 -15’s rear.
Vette Brakes front mono leaf suspension, Vette Brakes upper and lower control arms, manual steering box, all new steering components, Vette Brakes rear mono leaf, Van Steel rear trailing arm assembly’s, 1981-one-piece rear aluminum differential cover and crossmember, 373 gear ratio.
ATl fuel cell with custom fabricated mount and fuel filler neck, Mallory electric fuel pump, filter and regulator. Custom fabricated fuel pump and filter mount, II Much fuel vent.
Custom fabricated and tig welded 4-point roll bar, 5-point harness, 68 Corvette seats custom covered in leather, custom leather door panels, custom leather kick panels, leather bound custom factory style carpeting, factory 65-67 Corvette gauges, original 66 Corvette 3 spoke steering wheel and horn cap.
This Corvette uses a nice blend of NOS parts, restored original period correct parts and some modern parts to make a truly one of a kind Grand Sport replica. THIS IS NOT A KIT CAR! IT’S A REAL Corvette with real corvette parts. No Power steering, No power brakes, No heater, No A/C, No Radio, No BS. It only has about 90 test miles on it and although put together over the course of the last 15 years it’s very fresh. Sounds good, runs great and fun to drive! Looks like it was just built and it’s a must see and drive car to truly appreciate all details. REDUCED Asking Price $125,000.00 Open to serious offers. More info and pictures on request.
603-647-4000 Ask for Jay
Attachments - The Supercar Registry IMG (9).jpg IMG (8).jpg IMG (7).jpg IMG (6).jpg
