Old 12-08-2017, 06:55 PM
Default WTB 1966 Chevelle / Beaumont Antenna
I'm looking for a correct original antenna base and telescoping mast for my 1966 Beaumont SD. The car is all original, so I'd like to use an OEM part, if at all possible.
I would sure appreciate someone posting a photo of exactly what I should be looking for. Thanks!
Old 12-27-2017, 08:00 PM
Bump
Old 12-28-2017, 12:56 AM
Helmut,
Ask here....
http://canadianponcho.activeboard.com/
Old 12-28-2017, 05:01 AM
67since67's Avatar
OK, maybe I can help with a couple pix.
I am assuming that Chevelle and Beaumont antennas are the same and you asked for telescoping mast, so not AM/FM.
You didn't mention front or rear antenna, a front will stand straight up of course, but you should be aware that a while a '67 rear stands pretty much straight up, a '66 rear should lean back slightly as shown in my side by side pic.
Good luck with your search! - Bill W
