Old 01-02-2018, 03:10 PM
chris slawski chris slawski is offline
Default 69 Nova automatic to 4 speed swap
Hello-
Need more guidance. I am swapping out the column shift TH350 for a M20 Muncie. The car will NOT have a consol. The question is can i use the consol transmission hump for shifter clearance?
Thanks,
Chris
Attachments - The Supercar Registry Muncieshiftaa14088415_10205524061015548_4522752969682260244_n.jpg
Old 01-02-2018, 04:57 PM
i did find it back in history on this site....thank you...no consol, no hump!
Old 01-03-2018, 07:59 PM
WILMASBOYL78's Avatar
Default shifter...
With bench seat or buckets minus console...the bench seat style shifter was used.
-wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 01-04-2018, 12:33 PM
Didn't the Nova have a bucket seat no console Muncie shifter too,like the Chevelle?
Old 01-04-2018, 03:00 PM
JRSully JRSully is offline
The factory, crudely, just torched a hole in the stock tranny tunnel/hump to allow access for a bench/no console 3/4 spd shifter
71 Porsche 911 Targa
Old 01-04-2018, 05:24 PM
Default shifter...
I'm not aware of a third shifter option with the Nova...it makes sense, but I've never seen one. Perhaps there is some assembly info or parts book numbers out there..??
I do know that the sound deadener that was installed under the carpet in the Nova...had a perforated cut out in the material for the bench seat style shifter.
-wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 01-05-2018, 09:14 PM
Crossbreed383 Crossbreed383 is offline
If someone were doing this swap from a 3-speed column to floor M21 would you just install trans and measure up for the hole? Or is there an other way to measure without cutting hole in the wrong spot is all.
Custom Cam /Engine Dyno and Spintron Operator at Brian Tooley Racing R@D
84 Mustang/Hertz Rent-a-Car
438CI 5.58@123 8.80@147 On Radials ALL MOTOR
Powered by my 13 year olds engine program
68 NOVA 396-375 HP F.A.S.T. Project
Old 01-05-2018, 09:24 PM
earntaz earntaz is offline
Just to be safe, I'd install everything and see where the shifter you are using will line up with the tunnel. Unless there is another way, you're just guessing were the hole should be. If you had another Nova with a factory setup to get measurement from, that would be the cats ass ... TAZ
Old 01-06-2018, 02:43 PM
Post nova floor shifter...
I have seen the measurements posted on Steve's Nova Site...if you visit there someone can help. As I mentioned, the factory sound deadener has a perforated knock out for the floor shifter...this was the same even on column shift cars...if you remove the carpet it should be easy to see.
-wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
