Old 01-06-2018, 05:50 PM
GM_427_Racer GM_427_Racer is offline
Default Miscellaneous Camaro & Corvette Parts
These are parts I am never going to use and they need to go. If you are interested, you can message me on this site or give me a call at; 33zero - two 1 9 - four seven three 8. If I do not answer, please leave a message and I will return your call.
Thanks for looking,
Gary Merrick aka GM 427 Racer
1967 Chevrolet Big Block L88 Intake Manifold – Two Casting Numbers 3885069 & 3886093 (Cast, not stamped) – Casting Date 9-26-66 $750.00
1968-1969 Chevrolet L88/ZL1 Big Block Intake Manifold – Casting Number 3933198 Casting Date 10-30-69. This intake also has thermostat housing casting number 3877660 with the integral carburetor return spring hole. $750.00
1969 Camaro NOS Upper and Lower Control Arms, with original GM Ball joints, uppers have rivets. These parts were purchased in the middle 1970’s and used very little and have been sitting in storage since the late 1970’s. No rust or pitting, painted black. $500.00
1969 Chevrolet Big Block Aluminum Closed Chamber Cylinder Head – Casting Number 3919842 – Casting Date 10-1-68 One only, and has damage to one combustion chamber $750.00
Four Original Rally Wheel Hub Caps with double ribs – P/N 3925805 $450.00
1958-1962 Corvette front turn signals NOS P/N 898717&898718 $225.00 for both
1958-1962 Corvette deck lid emblem NOS P/N 3796462 & Bezel P/N 3740240 $100.00
1956-1962 Corvette R/S Door Handle Only NOS P/N 4156542 $20.00
1968-1969 Corvette lower fiberglass fender parts w/louvers (used), Left & Right lower grilles and turn signals attached (used), Left & Right chrome grille moldings (new re-pop) $400.00
1969 Camaro Chrome Qtr Panel louvers – P/N’s 8724408&8724409 Revision 2 $50.00
1969 Camaro License Plate (Gas Door) – Has pitting $20.00
Old 01-06-2018, 06:08 PM
L78 Fred L78 Fred is offline
I’ll take the control arms and the lovers
Thank fred
Fred
[email protected]
610-585-4155
WANTED:
1969 396/375 hp JH Vin N6352xx Mid April 69 block 272 casting
Always looking for dated L78 parts from Jan-Apr 69
Old 01-06-2018, 06:10 PM
I’ll take the rally caps if they are nos as well for 69
Fred
[email protected]
610-585-4155
WANTED:
