Old 02-21-2018, 03:38 PM
L16pilot L16pilot is offline
Default Muncie Drive Gear - advice needed
Okay, so a few years ago, I had bought a rebuilt Muncie from Ed Hartnett and to detail it the way I want, I pulled the tail housing and side cover for refinishing. It has a 7 tooth plastic drive gear with the metal clip and for the combo I will be running I need to change it out for an 8-tooth 1.84 diameter.
Should I replace it with the plastic gear or the press-on steel drive gear? I realize the plastic gear is a weak link, but from what I've read, it is only is an issue if the speedo seizes. If I go with the steel gear, any issues pressing it on the output shaft using the input shaft as the support in a hydraulic press?
Steve Nuwer
1970 Z28, Norwood 03A, 48 48, 723 Int, M20, COO, 2021 Legends Platinum restored
1970 L78, Norwood 04C, 17 17, 711 Int, M21, COO, born-with drivetrain project.
1972 Z28, Norwood 11C project, born-with drivetrain, 26 26, 775, M20, CGG project
1970 Z28, Norwood 05C, 48 G, 720 Int, M21, COZ, Original Unrestored (SOLD)
www.2ndGenZ.com
