Old 03-01-2018, 06:20 PM
Hbigblock427 Hbigblock427 is offline
Default 1967 Corvette Restomod Coupe Dart 427 Fuel Injection
1967 Corvette Coupe RestoMod
$199,500
Call Joe (518)469-7765
http://www.prestigemotorcar.com/web/...York/31534569/
~CUSTOM 1 OF A KIND~
Redesigned with 21st Century Technology and Comfort Features
TIMELESS Marina Blue Paint, White Stinger & White and Bright Blue Interior
A Modern Day Muscle Corvette Designed by Joe Verrillo
Created by the Renowned Team at Prestige Motor Car Co.
Restored and Modified ~ Mid-Year with Super-Car Performance Technology~
This 590 Horsepower DART FUEL INJECTED 427 C.I.
DRIVERTRAIN SPECIFCATIONS
Custom built Dart "BIG INCH" 427 Cubic Inch small block Chevy stuffed with some of the best internal engine parts available on the market today including Dart Pro 1 215cc cylinder heads, Scorpion Roller Rockers, Chrome Moly Push Rods, Scat 4.000 Stroke 4340 Forged Steel Crankshaft, Scat 6.000 H-Beam 4340 Rods w/ARP Cap Screws, Melling Oil Pump and Icon 2618 Forged Pistons. This combination when topped off by a Dart SHP dual Plane intake manifold and FITECH "Mainstreet" Fuel Injection Unit is good for a GROUND POUNDING 590 HORSEPOWER and a breath taking 580 FOOTPOUNDS OF TORQUE!
Tremic TKO 5 Speed with Overdrive and Custom Silver Star Transmission Shifter. You will be blinded by the chrome under the hood! Billet High Polished Aluminum Pulley System, Chrome Alternator, Chrome Air Conditioning Compressor, Heavy Duty Polished 4 Core Aluminum Radiator with Dual Chrome Fans. Exiting the Heavy Breathing Engine area Hooker Headers Side Exhaust Mufflers with Factory Covers. Riding on Chrome Spider Z06 Wheels 18 x 8.5 P245/40ZR18 Front and 19 x 10 P285/35ZR19 Rear on Goodyear G FORCE Tires.
CHASSIS SPECIFICATIONS
Street Shop the Leader in Exact Retro For Chassis. Dana 44 Viper Rear End Assembly Gear Ratio 3:55 Designed & Built Exclusively for this Chassis by Street Shop. All Aluminum GM Corvette Suspension with Chrome Coil Over Adjustable Springs. Polished Rack and Pinion Steering. Stainless Steel Brake and Gas Lines. Stainless Steel Fuel Tank. GM / Z06 Big Brake 6 Piston Front Calipers, 4 Piston Rear Calipers with Ceramic Brake Pads and Drilled Rotors. Calipers are Custom Painted Marina Blue!
The uniquely applied custom wide fender body design was applied on the West Coast of California the birth place of Hot Rodding! Carefully applied not to stray away from the factory General Motors design these custom fenders add a total of 4 inches to the total width of the body to accommodate larger wheels and tires to handle the massive amount of Horsepower and Torque supplies by the radical engine under the timeless design of the 1967 STINGER Hood!
