Old 06-13-2018, 05:50 PM
auwrestling auwrestling is offline
Default 1972 gto 455 ho 4 spd ww5
1972 GTO WW5 for sale.
Lucerne Blue w/ White top and Interior. 1 of only 310 built with the 455 H.O. and the M22 Rock Crusher. In addition, only 290 of the 635 H.O. cars built in 1972 were ordered with the WW5. That 290 number includes BOTH manuals and automatics. The entire drivetrain is original to this car with the exception of the BLOCK only. It currently has a 2 bolt 455 block But a correct "WM" code short block goes with the car. Everything else is original incl. Heads, Intake, Carb, Unitized Distributor, M22 RockCrusher and 12-bolt 3:55 axle. Original Ram AIr Pans & Boots are also present.This is a very solid car that deserves a good restoration. There is some repair work needed at fender bottoms and lower rear qtrs. right behind wheels. Not too much rust in these areas but it is present. Floors, Rockers, Doors, Window surrounds etc are ALL solid.
Hood IS bent unfortunately. Deck lid had holes from prior owner mounting a wing.
Car Runs And drives
This is a very RARE car in a very desirable color (Lucerne Blue).
$28,900. Call or text 716-536-2047
