Old 07-04-2018, 03:43 PM
scuncio scuncio is offline
Default 1968 Camaro 12 Bolt BU 3.73 Posi Assembly
Nice BU code 12 bolt rear that needs restoration. Clean housing dated March 1968 with a May 13, 1968 assembly stamp. Has 4.88 gears and 4 series posi so you will need to source the correct internals if you want to return to original. $1850, pickup only unless we can make a special arrangement.
