Old 08-04-2018, 04:53 AM
scuncio scuncio is online now
Default 1969 Z/28 Complete Drivetrain - Engine, Trans, Rear
Matched set from 124379N640398?
Link to 1969 Z/28 Drivetrain auction
Old 08-04-2018, 02:51 PM
I suppose all of the soot will come off?
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle
Old 08-04-2018, 03:58 PM
Thanks for posting that Tony. The VIN for the engine and trans is 600+ numbers off the one from my car so it was likely from a car built 1 day before mine in early May. I talked with the seller today and he appears a straight shooter.
While we were talking someone put a bid on it which now means the auction will carry out to the end according to seller. Shows he has some integrity which I like. Told him I do have serious interest as the dates are perfect for my green car but we'll wait to see how the auction plays out.
If not I've already got a freshly built CE motor sitting here so not a big deal if it becomes a runaway train. Will be interesting to watch.
Old 08-04-2018, 08:21 PM
Hope you can make a deal Graeme.
Old 08-04-2018, 08:29 PM
He sent me additional pics and the heads are mismatched with the intake being is 64/65 Corvette. Most of the peripherals are wrong but the block, trans and diff are what interests me. Hopefully it's still std bore and journals but one never knows when it's all together like it is?
Time will tell.
Old 08-05-2018, 01:05 PM
Fast67VelleN2O's Avatar
Fast67VelleN2O Fast67VelleN2O is online now
My car is around 1000 units off this engine and transmission combo. About as close as I would ever get but the fire scares me a little bit.
Day 2 is Life.
Old 08-05-2018, 01:27 PM
Yup...you'd never know if anything was warped or distorted from the heat until you setup to machine it or restore everything. Three cars were destroyed in the fire and if there was enough heat it can take it's toll when reaching 1600 degrees? I really wonder if the diff tubes were affected by that and would bet they'd need truing.
Old 08-05-2018, 02:21 PM
ALLZS ALLZS is offline
I just worked on a muncie 4 speed that come out of a car fire had a lot of alinement problems had to use a differant main case
Old 08-05-2018, 05:06 PM
In my experience the best way to tell is to look for oil coking on the inside of the valve covers, pan, trans case, etc. If it's crispy you're probably in for some work.
Old 08-05-2018, 05:07 PM
Not that it would provide that much insight, but I'd like to see pics of the car this came out of. Just to see how much of a disaster it was before it was parted out.
