For Sale, SOLD on eBay
Vintage USED Moroso REAR sump 6 Quart street/strip 62-67 ChevyII oil pan. Comes with USED Z28 Gm performance oil pump #14044872 or casting #3732796. This is a high volume pump that was blue printed with 60psi cold & 20psi hot. It has the correct pickup #24120 tac welded on. Also has the cut out for the Nova steering linkage. This pan is for a two piece rear main seal {Pre-1980 blocks} Dip stick is for driver side. NO POWER STEERING!!!!! Pan depth is 9" and will clear bumps easily. There are no dents or scratches in pan..very clean Pan that will work with a factory windage tray if needed. Moroso does not make this design anymore, they are more square now instead of rounded edges. Freshly painted pan and ready to bolt on. Small Block Chevrolet Moroso oil pan/pickup with magnetic drain plug. GM Z28 high volume oil pump. Shipping in the lower 48 states only. $150.00 Shipping will be $32.00 PM's or... 267-261-6549 https://photos.app.goo.gl/kVtRepdVfRD1ck4T9 https://photos.app.goo.gl/s14by9xj2hYnGKKNA https://photos.app.goo.gl/2WWWNksgF7QyXjx2A https://photos.app.goo.gl/RURcXencEzBpbE4C9 https://photos.app.goo.gl/SUu8zcSghERUsoJJ8 https://photos.app.goo.gl/4ZVD1H5JZHkFQYnc8 https://photos.app.goo.gl/PFx3AhHRp3L81siN8 https://photos.app.goo.gl/yzKNyxvbiVMXJfjx6 https://photos.app.goo.gl/sNeyJiKZ8RRCvnFY6 Dave 67 Nova Boy Last edited by 67 Nova Boy; 08-27-2018 at 05:40 PM. |
