Old 09-30-2018, 01:59 PM
dlv4540 dlv4540 is offline
Default 1969 396-375HP JH Camaro Engine
Late built 1969 Camaro 396-375HP engine casting number 3969854 dated G-2-9 standard bore stamped T0725JH and vin stamped down by the oil filter is 19N680592. Block is cleaned and magged and should stay standard bore. I have the original heads 3919840 dated C-26-9 & E-5-9, 3933163 aluminum intake dated 6-17-69, steel 6223 crankshaft, original pistons and dimple rods, 8 inch harmonic balancer and timing cover along with the oil pan. Asking $6,000 or best offer and can ship if you cannot pick up. Any questions I can be reached at 330-770-2517 and can provide pictures as well. Heads were cleaned and magged and the intake was cleaned up as well. Crank is standard and clean.
Dennis Vugrinovich
Old 10-07-2018, 05:39 PM
Motor is sold.
Dennis Vugrinovich
