Old 11-05-2018, 08:13 PM
70LT1Z28 70LT1Z28 is offline
Banned
Default 68 z28 correct pcv valve
Hi guys can someone tell me what is the correct pcv valve for 68 z28.
Old 11-05-2018, 09:21 PM
Chevrolet saw it as #6484525
AC saw it as #CV746C.
Both 1968 & 1969 Z/28's came with it.
Old 11-05-2018, 09:32 PM
Banned
i ask jerry macneish he said AC 736
Old 11-05-2018, 09:45 PM
Original 1969 Chevrolet Parts Counter Book dated 1968.
Are you sure he said CV736C?
1967 Z/28 shows CV726C,1968-69 Z/28 CV746C,so I would think one of those two.
Old 11-05-2018, 10:11 PM
Banned
thank you Mr 70. i ask jerry because is knows 1st gen
Old 11-06-2018, 10:30 AM
JKZ27 JKZ27 is offline
www.camaros.org/forum/index.php?topic=12453.150
Here's a link some pics of an original Z.
Page 11 shows the CV746 pcv. Though, I think the early originals were machined not stamped.
Old 11-07-2018, 12:28 AM
169indy's Avatar
169indy 169indy is offline
Here is my as found 746C on my Dec Los Build. I suppose it could have been changed out over the years, as in the Machined -vs- stamped formed versions. As an additional comment or question, Can these things be cosmetically restored via a cold brite zinc plating process w/o detrimental affects to the check valve ball inside?
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 11-07-2018, 01:01 AM
Banned
thanks guys for your help.
Old 11-08-2018, 02:01 AM
Kurt S Kurt S is offline
736 is all 68-69 V8 except 302.
Kurt S - CRG
Old 11-08-2018, 12:42 PM
I would think it would be easy to zinc plate them. It is air-tight in construction so with some care to plug the ends with some tight fitting rubber plugs that would prevent any chemicals from getting to the interior. Just to verify, plug one end and connect a mighty-vac to the other end and see if it holds vacuum. If so you are good.
Owned since 1978 - First Car
