Old 12-19-2018, 07:39 PM
EZ Nova EZ Nova is offline
Default Most accurate site for muscle car weights
As I said in the ZL-1 Vette thread, we re looking at running some races for muscle cars. So looking to know where is the most accurate weights for all makes that we can look up and maybe use as guidelines for each car?
We do not want a '69 BB Nova to have to weight as much as a '69 Chevelle or Impala. There was a reason why some cars were better "streetfighters" than others. Like M-code '69 Darts too.
Thanks in advance, John
'78 Z28 4sp being restored
'70 W30 convert TRIBUTE
'66 CANADIAN Nova SS Race Car
'69 FIREBIRD Tubbed Racecar
Attachments - The Supercar Registry 7C4CE9A6-A9DD-4229-8062-EBA975E14F60.jpeg
Old 12-19-2018, 07:53 PM
https://www.automobile-catalog.com/
Most but not all. They use Curb weight which means all fluids installed and a full tank of gas
Old 12-19-2018, 08:00 PM
Here is an example" 1969 Z/28
Second Page:
https://www.automobile-catalog.com/auta_details1.php
Old 12-19-2018, 08:20 PM
Thanks Lee. I was looking at that site once you posted it in the Nova thread.
Old 12-19-2018, 09:32 PM
Sean Sean is offline
Sounds like a neat deal! Just be prepared to listen to the whining about the rules and have thick skin. Long time racer here and let me tell you be firm and fair.
70 LS 6 4 SPEED CHEVELLE
69 SS 396/375 HP 4 SPEED CHEVELLE
68 SS 396 CHEVELLE SS 396/375 4 SPEED
69 COPO CHEVELLE 4 SPEED #S MATCH
69 COPO CAMARO #S MATCH SURVIVOR (BLACK)
69 COPO CAMARO (BLACK)
55 GASSER L88 4 SPEED
66 NOVA "UNDER CONSTRUCTION"
70 440 SIX PAK CHALLENGER SUPER STOCKER
2001 RVW/LDR TRANS AM 1020" BBC 8 SYSTEMS
Old 12-20-2018, 03:40 AM
John Brown's Avatar
nhraracer.com
Look in the stock car classification guide area for shipping weights.
John Brown
Old 12-20-2018, 05:03 AM
RobR RobR is offline
Years ago we would use the NADA Guide to get the cars shipping weight.
Old 12-20-2018, 02:10 PM
Thanks guys. Maybe get all 3 and take an average of 4sp weights for that car. NOt trying to figure each and every possible combo, but say a '69 BB Camaro, it would be based of BB 4 sp and that is it's weight.
Old 12-20-2018, 02:21 PM
Not going to be many rules. Actually pretty simple.
1. Weight for that car (example '69 BB Nova 4sp must weigh say 3300 lbs)
2. Must run OEM steel wheel, like a GM Rally wheel. Max 15" diameter.
3. Must run dual plane intake. Weight break for OEM dual plane.
4. No power adders of any kind, Nitrous, turbo, supercharger or nitro.
Tires were looking at up to 275/60R15 or 9" slick by sidewall designation.
The intake will take a lot of things out of play. Heads, carb engine size etc. You can only get so much through the dual plane intakes, it won't matter if it's a 706 or SR20 heads. You can port the intake, but not move the ports around pass where a gasket match will be the rule to a know standard.
This is going to be some executions, like if there isn't a readily available dual plane for that engine, and where to put "special" cars like ZL-1's. Stock style repop rims and intakes are cheap and we feel it's better for the class. EFI like FiTech/Sniper will be allowed, but not port injection with fuel rail conversions.
Old 12-21-2018, 02:36 AM
442w30 442w30 is offline
Find AMA Spec sheets. You can find a couple here:
https://catalog.hathitrust.org/Record/100573546
https://core.ac.uk/search?q=%22ama%20specifications%22
