In this listing I will continue to post multiple Corvette items
3 original unrestored vented gas caps, 63 through 70. $50 each, or all three for ALL SOLD $120. ALL SOLD 68 true 69 Corvette early tri-power accelerator cable mounting bracket. Without return spring hole. Very nice original piece with original Bolt. $50 68 through 72 windshield wiper door actuator accordion boot. Original thin wall design. $40. 3 available. 68 through 74 motor to frame ground cable and bolts. $40 each. 2 available. Excellent original Survivor condition. Original 68 through 72 windshield wiper door override knob, solid black. $50, 2 available Last edited by Enoch; 12-29-2018 at 02:39 PM. |
What month did the tri power cable mounting bracket get the hole for the return spring?
Thanks
65 Corvette Coupe L78 67 427/390 Vette Coupe unrestored 67 L-79 Vette roadster (Top Flight) 69 L71 Roadster Survivor 69 L46 Roadster Survivor (Sold) 69 Z/28 RS (Sold) 69 Dodge Charger R/T 70 W30 442 Auto Air Survivor 2016 Z06 Coupe M7 70 AAR Cuda (Sold) 69 L78 Chevelle (Sold) |
Actually thanks for pointing that out it's 69 that has the extra return spring bracket and no hole. 68 had the hole and they switched it because it interferes with the secondary linkage. I'm not positive when they switched it over.
66 67 and 68 427 radiator saddle brackets with original rubber and the original grade 8 RSC head marking bolts and large oversized washers. Perfect for a survivor car. Completely unouched. SOLD $100 shipped to the lower 48. SOLD
65 route 74 big block rear axle caps and mounting bolts. Original restored. The reproduction caps don't fit correctly. WB head marking on the bolts. Excellent restored condition. $100 shipped to the lower 48. Three sets available with WB head marking bolts and four sets available with BTS head marking bolts. Ppff
(Edit two sets with WB head marking left.) Last edited by Enoch; 01-29-2019 at 07:20 PM. |
63 to 72 dimmer switch with flat end, no recessed dimple by the rivet. They don't reproduce these. Excellent condition also included are too original dimmer switch screws with original turn down tips and self cutting threads. Another item that is not being reproduced correctly. $40 shipped to the lower 48 ppff. 2 available
One pair of NOS 63 to 72 under car exhaust ground straps. These are the ground straps that go from the transmission crossmember to the guillotine clamps connecting the front head pipes to the rear tail pipes. Excellent original pieces. $100 shipped to the lower 48. Ppff
65 through 74 big block power steering alternator and pump mounting hardware. All original Hardware they don't reproduce these with the correct head markings and grade. $100 shipped to the lower 48 ppff
1. 63 through 72 front pinion snubber bolt. WB head marking grade 8. Perfect original unrestored condition. $40
2. 63 through 72 strut rod 2 rear mounting bracket bolts, WB head marking grade 8. Excellent Survivor condition $50 3. 63 through 72 rear end 2 crossmember and rear end crossmember to frame mounting bolts. WB head marking grade 8. Excellent Survivor condition $60 4. 63 through 72 NOS rear outer leaf spring cushion washers with stampings and nuts with markings. $60 5. 63 through 72 rear trailing arm front pivot bolts, P head marking grade 5. Excellent Survivor condition. $50 6. 63 through 64 rear end pinion bracket to rear mounting bolts. Long M Bolt grade 5, short and bolts grade 8. Excellent unrestored condition. $60 All prices include shipping to the lower 48 if paid with PayPal friends and family. |
Pic
