*29293 Diverter Valve un-restored with elbow extension attached and mounting bolts/gasket as shown.For 1969 Small Block 307-327 w/M/transmission.$300 shipped to lower 48 only.
*29297 Diverter Valve un-restored with elbow extension attached and mounting bolts/gasket as shown.For 1969-1970 Special Hi-Perf Big Block.$600 shipped to lower 48 only. ~COMPARE THE PICTURE OF THESE TWO DIVERTERS SIDE BY SIDE AND NOTICE THE SLIGHT DIFFERENCE OF THE CLOCKED POSITION OF THE VACUUM HOSE TEE....NEARLY IDENTICAL. *1974 Pump un-restored with original black fan.Dated 08142 and I can't make out the last character.May be the bottom of the letter S.. It Spins & works as designed freely by hand.Comes with your choice of #3927116 pulley and 3 mounting bolts.$150 shipped to lower 48 only. *1968 Pump un-restored with original black fan.Dated 13481Y.Spins & works as designed freely by hand.Comes with your choice of #3927116 pulley and 3 mounting bolts.$300 shipped to lower 48 only.(The black fan is off this pump in the photo,but it is included) *Pump cradle Big Block.Early with no holes at all and comes with long mounting bolt attached.$150 shipped to lower 48 only. *Pump cradle Small block I believe?Early with no holes at all and comes with long mounting bolt attached.$100 shipped to lower 48 only. *Bracket lower Alternator with DSL stamping & Bushing.$100 shipped to lower 48 only. *Bracket lower Alternator w/o bushing or stamping. $15 shipped to lower 48 only. Last edited by Mr70; 02-05-2019 at 11:19 PM. |
