I have a good running 396 L78 motor out of a 1969 Chevelle 4-speed with an original casting date of D8-9 (April 8, 1969).
![]() Original 4-bolt main block with the big plug by the oil filter. ![]() The numbers stamped in the deck are T0610JD 19B394809 (assembled June 10, 1969 for an L78-375 HP 4-speed Chevelle with this partial VIN). ![]() The casting numbers on the original square port heads are 3919840. One is dated C-12-9 and the other C-13-9. Sorry for the sizing of the photos ;-] ![]() ![]() I noticed that the motor was discussed on the following threads dating back to 2013: http://www.chevellestuff.net/1969/engines/index.htm http://chevellestuff.net/orphaned/or..._paperwork.htm http://www.chevelles.com/forums/15-t...19b394809.html If you own the Chevelle that this motor was born with, please send me a PM and we'll work towards reuniting the car with it's motor. The motor is in excellent running condition (did not run hot) and was purchased from a reputable Chevelle owner. I have a video of the running motor that I can text. This motor needs a distributor, carb, a good degrease and fresh paint... and this motor is ready to be dropped into your engine bay! The motor is located in Elmhurst, Ill. I will keep it if I can ship it home. I'm asking $6,500 or beast reasonable offer. Thanks |
I must do some house cleaning (actually I'm trying to cleanup Dan's garage), so $5,500 USD will put this motor in your engine bay! Not literally... you'll have to install the engine yourself ;-]
Bump... $5,000 USD
This motor will be available for pickup in the Chicago area if you're heading to MCACN.
Make me a reasonable offer, take it home, and drop it in your car! |
