1958 Corvette
VIN# J58S105452 BODY Fresh paint in 2006 (approx. 3000 miles driven since painted)– paint on the car is show quality!!! Black w/Silver coves with deep shine and laser straight. Front bumpers re-chromed New grill molding Grill teeth & bar not replaced VGC Rear bumpers original GC New trunk irons/tusks All emblems replaced w/NOS Side trim and fender/cove trim new or polished New front parking lights Rear chrome brake lenses not replaced (good condition) w/LEDtail lamps upgrade INTERIOR Custom professionally made leather interior including seats, das pad, door panels, carpet, kick panels and trunk area. The cost to do the custom interior, trunk and custom made soft top was around 20K New or rebuilt gauges (all work properly) AM/FM CD with USB hook up Custom Auto Sound radio with built in speakers in kick panels and a dual speaker in dash New shifter console plate New door weather strips & new window felts Hush mat installed (sound deadener under carpet to quietride) Corvette Central electric windshield wiper upgrade ki New ignition switch New headlight switch 15” leather wrapped steering wheel ENGINE &ENGINE COMPARTMENT Polished Be-Cool Aluminum Radiator Polished Radiator overflow tank Electric Fan w/manual switch on dash New Fan Shroud Tach Drive Generator (Rebuilt) New Voltage Regulator Ram Horn Exhaust Manifold New original style exhaust system HEI ignition New motor bracket and mounts Engine 383 Full Roller Small block Est.450 HP (Built in 2014) New GM performance Block (4 Bolt Main) Eagle street strip rotating assembly Edelbrock Performer RPM Heads Polished Edelbrock Performer RPMHydraulic Roller Cam kit Weiand Action Plus intake manifold Holley 750 cfm CFM carb with vacuum secondary’s,electric choke Performance cam bearings Milodon Pan 30700 Fel-Pro gasket set Fel-Pro HP head gaskets 1 Pc pan gasket Fel-Pro Power Master Balancer GM Distributor gear ARP Head Bolts SS Roller Rocker arms SCP Timing Chain set Roller Oil pump 55 HV Melling Select Brass soft plugs TRANSMISSION &CLUTCH Muncie 4-Speed Transmission completely rebuilt with 4thGear overdrive New transmission mount New Hurst Shifter Original style bell housing New inspection covers New linkage Dual friction Center Force clutch REAR END GM 12 Bolt 3:73 Gears Rebuilt posi unit (new clutch packs and bearing) New pinion and axle bearings and seals New universal joints installed in drive shaft CHASSIS &BRAKES Original 1958 Frame is in very good condition painted satinblack (no rot or patches) Original rebuilt front suspension (all new bushings and coilsprings) Front power disc brakes New rear brake shoes and wheel cylinders New emergency brake cables Steeroids power steering rack and pinion with ididit steering column and linkage New Delco gas shocks New Brake lines New Gas Tank, Gas Tank Straps and Sending unit Total wiring harness replaced HARDTOP New headliner All weather stripping replaced All glass replaced Rear window has a scratch SOFTTOP Custom made convertible top Frame complete & working New weather seals WHEELS 15” Halibrand Style 5 spoke polished aluminum I have a lot of pictures let me know what you need, 82,500.00
69 RS SS L78 conv 69 RS SS ZL1 69 L78 Chevelle conv 69 L78 Nova 69 L34 Nova 67 SS Chevelle 73 Trans Am |
The Following User Says Thank You to ssl78 For This Useful Post: | ||
Arrowsmith (06-13-2020) |
Cool car
still available.
price 82,500
69 RS SS L78 conv 69 RS SS ZL1 69 L78 Chevelle conv 69 L78 Nova 69 L34 Nova 67 SS Chevelle 73 Trans Am Last edited by ssl78; 07-24-2021 at 04:25 AM. |
