Old 09-17-2020, 03:10 PM
mhm1966 mhm1966 is offline
Default Starter Nose Drive End
Starter Nose Drive End. This part is cast iron and can be used for 153 teeth or 168 teeth flywheel, automatics or manual transmissions. 153 teeth flywheel uses a #403 style bell housing with a starter that has a straight across bolt pattern. 168 teeth flywheel uses a #444 or #621 style bell housing with a starter that has a staggered bolt pattern. With manual transmission and 168 teeth flywheel the cast iron starter nose drive end is required. This part has never been used and still has a white stamp on it from the manufacture. $40.00 plus shipping.
